Hi @ all, I’m using lightburn for my GRBL Ortur Laser Master 2 with the newest version. Love all the features, but still learning to wirk with. I updated the „Fire“ Button and want to frame my position by pressing „Shift“ to see if my alignment is correct. But unfortunately the laser burns into my objects
Where’s problem?
In the ‘Move’ window, what is the Power value set to, next to the Fire button? (the frame will use that power value when framing if you hold the Shift key)
Jeah, i hold shift and then klick Frame. The laser goes his way and I’ve set the power manually to 0,01%
It burns the surface
Type $$ in the console and press enter, the copy & paste the text it emits back to here (those are your firmware settings). Then go to Edit > Device Settings and tell me what the ‘S value max’ setting in the lower right is. The $30 number in your firmware settings should match the S-value max parameter in LightBurn (or vice versa).
I see nothing wrong with your settings, so I’d guess you either have a wiring issue, or a faulty machine.
Hmm okay thanks, then i have to live with that issue. Thanks a lot for your patience
