Laser burns path line when it should not
Sometimes my laser will burn the unwanted laser path line between images and text or visa versa.
In preview mode, it will show the laser path between objects but how do I know if it’s going to burn or not burn the path?
It should never bun the path line. If you turn off the ‘Show Travel Moves’ switch, the image shown won’t have the moves between cuts, and that’s the output you should get on your laser. You most likely don’t have ‘Laser Mode’ enabled.
Read here:
Thank You for responding
