Hello everybody. I’ve tried to find a specific answer to this question in the existing forum entries, but couldn’t come up with one. So here’s the situation:
Last time I fired up my laser was about 8 months ago. We moved and just haven’t had time to use it. The new climate is MUCH colder than our old one - not sure if this contributes to the situation, but figured I would include it just in case. Laser seems to be in good order. Everything turns on and initial test burns of my tried and true test file were good.
The problem started when I began attempting to burn some more delicate designs that my wife had been working on. I found that my laser simply won’t fire on any layer with a power setting below 20%. Actually, it will start to fire on settings as low as 15%…but then it cuts off and I have to turn the laser off and then back on to get it to fire again. But with settings at 20% or higher, it’s like old times. No problems.
I have definitely burned as low as 10% in the past. Nothing has changed with the laser, its setup or its settings. I literally moved it from one place to another. Then waited a few months before turning it back on.
The only notable difference, as mentioned above, is the temperature. For example, my ‘chiller’ used to run at about 30 degrees celcius…but here in the new location it is running at about 20 degrees celcius.
I did notice that on the main screen of my Ruida controller it says MAX POWER: 50%. The thing is, though, that I had never really noticed that before, because I wasn’t looking at it before. But while reading some other threads it was mentioned, so I took a look. I also saw some people discuss manufacturer min/max settings, but I don’t have the password to access those…so I’m certain that I haven’t changed them
With that said, as soon as a file starts from Lightburn that MAX POWER settings changes to whatever the file is set to in Lightburn.
Also, I have tried running files over USB, but have also sent files to the machine and stored them there to test with as a way to make sure the problems isn’t related to the connection.
Has anyone else had this issue? Any ideas on how to resolve? Please advise.
Thanks in advance!
SYSTEM INFO:
Ruida 6445 Controller
Reci w2 80w/90w Tube
