Laser connected, shows ready but no laser control (Ubuntu 22.04.3 LTS)
Hi all.
I already did test lightburn with Sculpfun S9 successfully in Demomode.
Now (few months later) I finally did buy a GPBL licence for it.
Now I see the laser is connected (GRBL, ttyUSB0; → Laser Ready) but I can not control it.
I did check the baudrate: 11500
lsusb: “Bus 005 Device 002: ID 1a86:7523 QinHeng Electronics CH340 serial converter”
addusr to tty: sudo adduser $USER dialout && sudo adduser $USER tty
What can this be?
Any hint where to look?
In the Console ox of Lightburn I see repeating message - blocks that might be the problem.
ets Jun  8 2016 00:22:57
rst:0x3 (SW_RESET),boot:0x1b (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DOUT, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:8896
load:0x40080400,len:5828
entry 0x400806ac
entry 0x400806ac
This is showing a boot loop. The firmware has crashed. You need to flash it again. A guide is here: Firmware Update & Settings - Diode Laser Wiki Select the S30 firmware, since your laser has an S30 mainboard.
Danke - das war es tatsächlich.
Ich habe aber die Firmware für XY DLC32 (Also S10) übertragen.
