Hi everyone. Is there a way for me to change the size of my model but keep the same slots and tabs.
I have a file designed for 3mm MDF. I want to make the model larger but would like to still do it with 3mm MDF. The tool gives me option to change between different size boards say from 3mm to 4mm, but cannot change from 3mm to 3mm. Is there a way to do this or must I do it manually
I don’t believe there is any way to resize your design without affecting the slots and tabs, but the resize slots tool is quick and easy to use after the fact.
