I am reconditioning a 100w laser and I am surprised at some of the test results. When I do cut/engrave tests, I’m seeing cutting engraving power peaking at about 45% (using a myjg100c PSU). I’m not sure about the life of the laser tube, but I suspect it’s coming towards the end. So my questions are:
- Is it normal for the power to be in a “hump” where the cutting power tails off after a certain percentage?
- How does the power/speed performance compare to a fresh 100w tube?
Notes:
- The material is a 6mm (soft/light) poplar ply
- I have set the DSP max laser power to 65% as this corresponds to 25-27ma read on analog amp meter and digital readout on laser PSU.
- It’s unlikely to be caused by mirror misalignment - I see the same result across multiple locations of the laser bed (corners, middle etc)
- It’s unlikely to be material-related. I see the same for acrylics
- The fading of the “Cut Test” title is sanding, not lack of laser power.
