I just got my new Aeon Nova 14 CO2 laser a couple weeks ago to cut closed cell Polyethlyne gun case foam. I designed my layout as a sketch in Fusion 360, saved it as a DXF and imported it to LB. The sketch looks fine in LB preview, except for one thing. The program refuses to cut the outline shapes on one pass, it has the straight lines and curves divided up so it will make all 6 passes on the line, then cuts all the passes on the curve, the next line, and so on. My sketch in Fusion is clean and fully constrained.
Now the bigger problem, the laser is cutting random unwanted lines and curves. I’ve already scrapped quite a bit of material so this is getting frustrating. These cuts don’t show up in LB or Fusion so I have no idea what to do. Begging for some help!
I’m not sure about the random unwanted cuts but if you select everything then select “Auto-Join selected shapes” that will certainly help with your first issue.
Great, I’m pleased that worked to fix your issues. If you wouldn’t mind marking my post as the solution it can help others who might have a similar issue in the future find a solution too.
