my laser is cutting upside down,cant figger it out please help.
Your origin is likely setup incorrectly. Go to Edit->Device Settings and set Origin to top-left for your laser.
However, this implies that you didn’t use the .lbdev configuration files provided by xTool.
Suggest you follow the setup guide here:
Use LightBurn to Operate xTool D1 Pro – xTool
ok ill give it a try thanks.
thant you so much worked fine.
you are a life saver.
