Laser distance from the wood
Hi all, so I’m two days in using light burn, I have been successfully print once…. The issue I think is my wood is below the platform of my laser. I’m trying to burn onto a whiskey barrel. I see the laser, nothing happens. If I put a 1” piece of wood on top it burns perfectly……i can physically move the laser down anymore. Any suggestions?
what model laser are you using? Does it have a focus sequence you must observe? Depending on the laser, there will be a spacer with which to set the necessary height. Based on your statement about an inch block, that’s likely to be the answer.
I assume that’s can’t move it down anymore.
Since you lift your test board into focus by and inch, you’re only other option is to lift the material up to get it into focus.
Just because it’s lasing, doesn’t mean it’s focused. The lens is what makes a laser really work by concentrating the emf to a smaller spot. Seeing it is nice with a visible laser, but that’s not the same as being in focus.
Or did I miss what you’re asking?
:grinning_cat:
Correct I meant can’t . I have to go 1” below the deck of the laser and the laser can be adjusted but it’s at the bottom.
Ortur LU1-4 spacer?
Hi @chrisplante
The laser needs to be physically positioned at its correct focal distance from the surface you’re engraving. LightBurn cannot adjust or compensate for that distance.
For the fixed-focus Ortur LU1-4, the nominal focus distance is about 29 mm. The supplied spacer/gauge is simply used to set that distance — it doesn’t change the focal length.
Since adding approximately 1" of material underneath your test piece makes it engrave correctly, that strongly indicates the barrel surface is currently too far away from the laser.
If the laser module is already at the bottom of its adjustment range, you’ll need to raise the barrel/workpiece by roughly that amount, or otherwise physically reposition the machine so the laser can reach the correct distance.
Seeing the laser spot on the wood does not mean it is in focus. This is before we get to the challenges of the barrel, I assume, being curved, and it being made of probably dark Oak.
If you go on ebay (not a fan of ebay) you can find 3D printed laser head focus adjusters. They generally give you an increased range of Z axis head movement allowing you to focus down and extra inch or so. You would lose a few millimeters of Y axis space because of the thickness of the focus adjuster. This would hopefully give you the extra range you need.
I did this with my Sculpfun S30 machine and got about 2" of extra travel.
