Hello, the laser does not turn off when it makes transverse movements. How can I fix? Thank you
My laser is Vevor 3018 Pro RGBL
Without knowing anything more about your setup this is typically caused by your machine not being in laser mode. Check the value of $32 in Edit->Machine Settings. This should be $32=1 for laser mode to be on.
Yes, it was set to $$32=0
I changed the value but I can’t test now if it works because I have to exit. Thank you very much.
