laser does not light up when fire button pressed
new 7w pro
new 7w pro
i was using the fire button just fine until i put on the new 7w pro
Is it only the fire button not working, or is it not firing at all? (if you run a cut or engrave, is that working?)
Are you sure it’s connected properly?
Yes it could not connected. I put the older laser back on and fire button still did not work
sure that the machine is connected to LB? can you post a SS of your console?
I can still engrave. Just no fire button. I checked all connections and all seemed tight and okay
Yes. I can still engrave
maybe the power of the fire button is too low? have you tried to up it a little bit? 2.5% or 5%?
No. But a good idea. I will try
dont really understand but changed $32 - 1000 fire button works
