JCF
(FLUHR)
1
Hi,
I have the following message.
Grbl 0.9i [’$’ for help]
Your Grbl may not support Variable Power mode (M4)
If your laser does not turn off between cuts,
switch to the GRBL-M3 device
My laser does not turn off between cuts, do you know this problem ?
Thank you
J-Ch
Edit -> Machine Settings, or in the console.
$100 and $101 are the X Steps per mm and Y Steps per mm. You would need to multiply whatever the current setting is by 50/62.
On my system, for example, my values are 160 steps per mm on both X and Y:
If my circles were wrong in the same way as yours, I’d enter:
160 * 50 / 62 = 129.03 steps per mm (you’ll have to figure out the right numbers for yours)
JCF
(FLUHR)
3
Thank you very much for your help, in fact the right value is 80 for X and 80 for Y.
