i could achieve good results so far with lightburn on my neje 30w laser with my modded ender 3.
I just have two problems. The vertical line is thinner than the horizontal. Is this cause of the laser itself? I have the best focus i could find. Even tried with different heights with other focus values.
On first picture the .ai file was aligned with the same spaced. If i burn it, i get these differences.
The other problem i have is that the laser wont cut still the place it started. Like on the picture and even if i try to cut normal rectangles
Hi, diode lasers don’t have a ‘round beam’ they’re rectangular so they will burn slightly thicker in one direction to the other.
I don’t know anything about your machine but have you checked the belt tension for your alignment problem? or could be it needs x and y axis recalibrating.
Hi, if you type in the search bar, top right of screen ‘calibrate axis’ there are threads there where you can find all the info.
Sounds like the ‘y’ and ‘x’ aren’t cutting true how they should.
Worth checking.
