Hello, I’m having some problems with my laser that I have bought few days ago. At first it worked normally but now when I try to move it with the indicators or I start the process, it moves a bit doing a sound as it was blocked, but the loading bar is still working.What can be the problem? Sorry but english isn’t my firt language
You are doing fine. If it helps you, use your native language and we can translate on this end.
This is not good, the system should be able to travel in all directions freely without binding or making any unusually odd sounds. Check all screws, belt tension, and general fluid movement. Clean and adjust as needed to have a smooth moving system. Do that, then update us here and we can go from there.
