My smoothie board went out so until I get anther on I’m using a Arduino uno with grbl v1.1h/ I’m using the spindle pin (Z+ on cnc shield board) to fire the laser with PWM. There’s a couple odd things but it works except the laser does not turn off between cuts. Using Lightburn version is 0.9.09. In the gcode there is a M4 to start but there is no a M5 anyplace. Not surprising since it’s using PWM
; LightBurn 0.9.09
; GRBL device profile, absolute coords
G00 G17 G40 G21 G54
G90
M4
; Cut @ 200 mm/sec, 7.5% power
M8
G0X103.67Y177.57
G1Y173.99S375F12000
G1X104.39
code go’s on till the end couple hundred lines
I expect this as during moves I would think the PWM would be at 0 volts( 5V in my case since I trigger on low) I have a oscilloscope connected to the PWM lead and it never goes high and stays high during a move. Stopping the code it does go high and laser is off.
It may have to do with power lever settings.
$30=5000
$31=0
$32=0
cut is set to 7.5%. (is set too 5000 to get 15ma current). 7.5% setting in CUT is because I’m just testing not cutting.
I’d guess I’m doing something wrong or over looking something. Laser is a K40.
Any thoughts?
Thank you
Doug
