Laser doesn't turn off when transitioning between cuts
When I’m cutting and etching the laser does not turn off when transitioning from cut to cut. It unfortunately creates a burn line across what it just finish cutting. It appears to be at the power level of the previous command but with increased transition speed. Is there a setting in the software that I need to adjust so that the laser turns off after each operation/transition so this doesn’t keep happening?
I have included a sample image so you can see what I’m referring to.
This should be simple fix. :slight_smile: Try entering $32=1 in your Console window, to put your controller into ‘Laser Mode’.
cela pourrait aussi venir de l’option sur la page de l’éditeur de paramètres de coupe…
This worked! Thanks for your insight. I’m new to this software so I still have a lot to learn.
