Need help. I am new to using a laser. I am using Window 10. I have a Ortur Laser Master 2 Pro. When I was Lightburn my laser doesn’t work. I keep getting the massage [ flame detector inactive luminosity too high]. I have used a LaserGRBL program and it burnWaiting for connection…
Port failed to open - already in use?
[MSG:Power Supply Problem:23V.Check TroubleShooting Section in User Manual.]
ok
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master 2 Pro S2]
[OLF: 188]
[OLH: OLM_ESP_PRO_V1.2]
[SN: F8DDC2A2808634D918815CADC3D9B50F]
[OLM:GENERAL]
[DATE:12:47:49 - Mar 5 2022]
[VER:1.1f(ESP32).20210403:]
[OPT:VNMZHSL,35,7680,3]
Target buffer size found
ok
Homing
ok
<Idle|MPos:0.000,0.000,0.000|Bf:35,7679|FS:0,0|Pn:P|CL:0,100|PS:2,1|ER:3997,3985|VA:23614,0|Ov:100,100,100|A:S|H:1,7>
ok
Starting stream
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 2:
Stream completed in 0:00
[MSG:Reset to continue]
ok
Ortur Laser Master 2 Pro S2 Ready!
OLF:OLF 188.
OLH:OLM_ESP_PRO_V1.2.
OLM:GENERAL.
[MSG: Flame detector Inactive. Luminosity too high]
Grbl 1.1f [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
oks well.
It looks like your issue is not in fact with the Flame Detector, but with the ‘ALARM:2’ message you’re getting. This alarm most likely means you’re selecting the incorrect 'Start From’ position.
Below are a couple of resources to help you get familiar with the way this setting works. Try using ‘Absolute Coords’ to begin with.
Thank You Problem solved
