Hello there
After the installation of the latest version 1.5.06, when I command the laser to engrave something with absolute coordinates (which is the method I always used since I bought the laser machine), I do the framing and after that the laser module goes back to home without firing and only the module’s fan works. The same happens without framing. The module just remains at home position without firing and only the fan works. I will upload the relevant videos.
The other problem has been occured is that the fire button in the move tab has been disappeared and not only there but also in the device settings menu where the fire button for enabling it, is missing. I’ve been always using for framing the laser spot and instead of that (after the latest version always), the red cross spot is used by the laser.
The good thing in all this matter is that the laser works normally with current position and user origin modes.
The laser machine I’m using is the Xtool d1 pro 10W.
Thank you very much for any help in advance.
Thaddeus
PS I’m trying to upload the videos but it doesn’t allow me. It says that the file I’m trying to upload is not authorized.
