Laser feuert nicht (Laser does not fire)
Hallo bin ganz neu hier. mein Ex-Mann kannte sich gut aus aber da wir geschieden sind muss ich es selber erlernen da ich Bestellungen habe die ich fertig erstellen muss. Da es Gestern noch funktioniert hat wollte ich heute Beispiele Erledigen aber auf ein, mal Feuert mein Laser nicht mehr, habe alles mögliche versucht aber ging nicht. bitte um ´Hilfe wo ich was falsch mache.
danke im vorhinein LG Sevgi
Hello I’m new here. my ex-husband knew it well but since we are divorced I have to learn it myself because I have orders that I have to finish. Since it still worked yesterday, I wanted to do some examples today, but one day, my laser no longer fires, I’ve tried everything possible but didn’t work. Please help where I’m doing something wrong.
Thanks in advance LG Sevgi
My laser has a separate switch at the side which can disable the laser. Might your machine have a similar switch?
Also, does your machine have a laser power meter? If so, does it show current draw while the job is running?
bei meinem Vector sind die Tastaturen so . vor einer Stunde hat es noch sehr gut Funktionen aber auf einmal feuert es nicht mehr. Ich habe Bestellungen zu erledigen muss die Fristen einhalten aber hab das Problem mit dem Feuern. bin schon sooo an verzweifeln :sob:
on my Vector, the keyboards are like this. an hour ago it still works very well but suddenly it doesn’t fire anymore. I have orders to meet deadlines but I have a problem with firing. I’m sooo desperate :sob:
With the set up that you have, is it safe to look at the control board for indications of what might be problematic? Many control boards offer blinking warning lights when things go wrong.
Is your laser Water Cooled? If so, is the water flowing?
A picture of the control board inside the Laser may help us.
yes,my laser is water cooled and the water is also flowing,thats not the problem.
i send you a picture from the inside maybe you can see somethin problamatic in there.
thanks.
Is there an X-axis motor or controller to plug into the 4 pin port marked X similar to the Y-axis plug next to it?
i just have this inside the controll board
