salve;
ho acquistato il modello PXW30W Fibra , purtroppo non viene visto da Lightburn sul mio iMac. devo acquistare la licenza o fare un aggiornamento?
salve;
Hello;
I bought the PXW30W Fiber model, unfortunately it is not seen by Lightburn on my iMac. Do I have to buy the license or do an update?
A fiber requires the Pro license.
I bought the Pro Licenze and the update licenze too; the problem is that I cant update more as my Mac is outdated. In this case may I should be refunded?
Not my decision, but I have not seen enough effort on your part to determine if it works or not.
We are in the weekend so it may be Monday before the Lightburn team can join in.
Unfortunately, that’s life when you live on the edge of technology. At the end of the last century I got a new G5.. about a $5 grand package. I knew Unix pretty well but I got along with the Mac well for a few years, then it wouldn’t update anything as they changed cpu architecture.
At that yearly cost, I dumped Mac os and put Debian Linux on it. Been on Linux ever since… however because of Lightburn, I find myself with a small windows 11 mini. Sometimes things just don’t go right.
It would be worth your while to either change your Mac hardware or your os to Windows or a newer Mac os with hardware.
Good luck…
Are you sure of your answer?
How you can say that, when you don’t know how many efforts I’m doing to resolve this problem?
Please, I sent to the support screenshot of this situation and until now no answer from!
Payed for update that cannot use because the Mac is obsolete is not a good commercial thing from Lightburn.
Maybe @MikeyH was a little harsh, but you’ve been here for 6 years and you’ve got to have seen the number of issues with older/newer Macs.
Mac has always been know for bleeding edge technology. However sometimes it doesn’t work out or they move to a software os that doesn’t have all the hooks or same interfaces that the older version has.
Eventually the hardware and software become obsolete. That is Mac and has nothing to do with Lightburn. My Mac did it to me, one day it advised the browser needed to be updated, when I clicked on update, it advised there no update available. No browser, I know things didn’t change overnight. There was no reason the browser shouldn’t work, Mac though otherwise.
If you choose to run obsolete hardware/software, you’re taking your chances with compatibility issues. I believe most of the update information specifies what Mac os works, I surmise yours isn’t one of them.
Whatever the case, if you don’t wish to run a version that does operate on your system, you have little choice. Even the new Macs will become obsolete.
None of this is due to Lightburn, it’s all Mac. Support has bent over backwards to help people, I find it hard to swallow that they ignored you. Every time I’ve seen anyone ask for a refund they were happy to oblige.
Maybe @JohnJohn can help you out or at least get you some attention to your issue.
I’m also disappointed that you’re unhappy.
Hang in there.
LightBurn makes a conscientious effort to support as many computers as we possibly can. No one likes to put newer computers into a workshop environment.
Which operating system does your Mac use?
edit : found support ticket with OS info Monterey 12.7.6 : iMac built late 2015
I found your support ticket and am following up.
LightBurn 2.2.00 requires MacOS 13 (Ventura)
@NicholasL responded to your support request on October 22 with the following.
If you have MacOS 12 Monterey you should be able to install and run version 2.1.04, it would be better than the older 1.4.05
I see the screen caps and and found your operating system version info there.
Please check your email spam filter to see if the responses from our support team were blocked there.
Thanks for helping out…
To use the Pro version of LightBurn for your galvo you need to keep the Pro upgrade that you purchased.
It will allow you to use any previous versions from the last calendar date within your previous (or current) year of updates.
