Despite my turning on the option in the device settings, the laser fire button doesn’t show in the laser panel ie software display. Otherwise it functions quite well. I even upgraded the laser to a 40 watt module. What could be the reason? My laser is a NEJE MASTER 2S MAX 30 watt.
Did you restart LightBurn? You need to, for this to take affect. You should then see it available in the ‘Move’ window.
DOH!!! Assumption and too lazy to read on my part, thanks for pointing me to the right spot.
PS: Even at 0% power my laser is still lit but there is no real power output. Thought it would turn it off.
