Laser firing but not burning
Hey there,
I have a Foxalien 20w diode laser that was working fine today until i swapped computers. Now the laser fires but does not burn/cut/engrave anything. I’ve tried lazergrbl as well and get the same results. Here is my gcode.
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=3
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=80.000
$101=80.000
$102=80.000
$110=3000.000
$111=3000.000
$112=3000.000
$120=400.000
$121=400.000
$122=400.000
$130=400.000
$131=400.000
$132=200.000
ok
If you still have access to the old computer, you should transfer all the LightBurn settings:
If it’s completely dead, then you must rebuild all those settings from scratch.
I have the old computer, but it has the same settings as far as I can tell.
What is the value of “S Value Max” in Edit->Device Settings? It needs to be set to 1000 if it’s not.
Also, are you using the units that you expect? Typically mm/min for diode lasers.
1000 for svalue max and in $30
mm/min for diode0
If you swap back to the other computer does performance revert to what you expect? If not, you likely have a hardware failure or other mechanical issue. Make sure that cables are all not damaged and well connected. Check lens for damage or residue and clean if required.
