Having a small issue where the laser wants to fire when is shouldn’t. This only seems to be happening when starting a file, not in between cuts. It also seems to only happen if there is a point at the set origin. I made 2 test files (shown in the uploaded pic) one with 4 squares one with 3.
If the origin is set and the file is started it works fine.
If the origin is set and the laser head is moved and THEN started, it will fire during its move to the set origin. But this only seems to happen if there is a point ON the origin.
If there is not a point on the origin then it will also run fine.
I’ve run a similar test (not shown) with circles (just so there was no point at the origin) and it will run without issue.
This does not happen when run through RD Works and it does not seem to be firing between cuts. just this starting issue.
