I just added a RDC6445G to my k40 and when I jog the x and y axis’s the laser fires but only when using lightburn. When I jog it using the panel it doesn’t do it.
How do you have the controller wired to the power supply? Can you show photos of which wires you’ve connected? I suspect you’re using a “high-trigger” input on the K40 supply, but Ruida by default is “low trigger”, so you might need to change that in the vendor settings.
I can’t see any of the input labels on the power supply. Do you have a pinout diagram for it?
It should be in one of the pics I attached.
