Hello All,
I am having an issue with the ring going red at start up.
I have a Omtech Polar 350. I am running Lightburn on a Dell mini PC with 16MB of RAM, Nvidia graphic, basically more then the minimum requirement.
I can load a program, set all my parameters, frame it no problem. As soon as I press “start” the light ring goes from green to red. It does not matter how simple the cut program is. I have tried to run the bypass switch on “rotary”, still does the same thing. I have updated the software and my licenses is current.
Last month, I would start a program and it would start to cut, then stop randomly with the red ring on. Then I would wait a bit and hit the unit button (red ring) and it would go green and finish. The axis are moving freely. Like I said, I have no problem framing. I always make sure the lid is down. It looks like the tray switch is being made.
Could it be coolant level? I can’t think it is the tube. I really don’t use it much and I cut leather. The power is never above 60.
Any Thoughts?
Roy
