Laser head crashes into home position
Laser head crashes into home position when I turn unit on. It works after some resets and emergency stops and other button pushing. But after a job when I restart the machine runs into the rail again and I have to keep doing stuff until I get it to work again. Very frustrating.I replaced the prox switch on the head a few weeks back. Worked fine until now. Indicates it’s working.
Do you have a cohesion board or a Ruida? It’s conflicting with your profile…
Since you changed out the home switch, I’d suggest you go over what you did and ensure everything is snugged up…
