Laser immediate stop after Start
So to preface the issue, I use Ortur Laser Master 2 pro and Master 3 pro from one singular computer. This wasn’t an issue but recently I changed the computer for a better model with the intention of better, less laggy work. Worked as intended but most likely caused a problem for my Ortur Master 2 pro.
The interesting thing is that the Ortur 3 pro laser works amazingly still.
So I connected the Ortur 2 to my old computer and low and behold… the Laser has the same issue on the old computer all of a sudden.
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master 2 Pro S2]
[OLF: 183]
[DATE:11:19:45 - Sep 1 2021]
[VER:1.1f(ESP32).20210403:]
[OPT:VNMZHSL,35,1024,3]
Target buffer size found
ok
Navádění
ok
At first I simply turned off the Shock detection and Flame detection with:
$262=0 and $259=0 and essentially everything you can find in the commands list in the lowest category I turned off. Didn’t work.
To describe what specifically happens when I try to run a piece, the Laser travels to a starting position from which it would start it’s work, but immediately stops, doesn’t even home to default position.
The sent message is all that the console provides.
Any solutions or possible fixes? I first want to ask here in Software category but I have a suspicion that the Laser’s hardware might be failing me.
Try updating the firmware and then get back to us.
