Laser is stopping before the job is complete
Hello, first post, completely new to laser stuff. I have a 30w Gweike G2 Pro, and am making some coins for USMC Vietnam veterans. I’m using a depthmap image, 3D slice setting, and have already run a couple, and have been tweaking settings. After my second coin, I changed a couple settings, faster speed, slightly lower power, and fewer passes. The preview looks normal, but then the laser stops firing a few seconds into what should be 45-60min cycle. This happened with the second coin, and I simply closed lightburn and then restarted and everything worked fine. I am using a laptop, and have already changed the setting to ensure my USB port is not going to an idle state. I have checked all connections, all seems good, but I cannot get this job to run anymore… I know I’m not over max speed or power or frequency in my settings… totally at a loss…
Hello,
Do you, at any point, hear the Windows “Device disconnected-chime sound”?
If you can, send us your .LBRN2 project file, so I can try to run this job on my G2.
