Hey. I hope this is the right section.
I bought a second “red and black” 130w co2 laser. First one is running fine, all good.
The second one - At some times I hear electric cracking noise, discharge somewhere near tube.
The first machine does perfectly engrave at 150mm/s and 9% power (mat finish, perfect).
The second machine even on 500mm/s and 9% power does engrave at least 0.5mm deep.
Both machines are supposed to be identical…
Any suggestions appretiated. Thank you in advance.
Update: So, cracking noise gone by itself and there is a little switch on tube PSU which enables power control.
