Laser just starts burning crazy design when framing
When framing a burn in Lightburn the laser just starts burning some crazy design.It does not do that in XTool create.
Turn off the laser function for framing or set it at the lowest possible %
or settings
Sometimes this is the result of installing a corrupted / cracked LightBurn program. If you downloaded the program installer from anywhere other than the Official Source, see what happens when you install a known-good version.
If the problem Goes Away, today would be a very good day to run a deep scan for malware, because you don’t know where that older version came from or what it’s been doing.
If the problem remains, pictures of what’s happening will help us see what you see.
