Laser just stops mid burn
Updated to the latest version and I’ve been doing some test lines to make sure the project fits. The laser stops mid burn and shows busy. Never had this issue before.
when I stop it the connection just stays “busy” so I have to reboot just to have it happen over again. Anyone had this issue?
Which version were you running before?
You shouldn’t have to reboot - right-click the ‘Devices’ button and that will close the connection to the laser and re-connect.
I don’t recal which version it was prior they are pretty good about constant updates. Never an issue before.
I would double check that all the connections between the laser and computer are secure. Does the other software you use with the machine have any issues?
No i switched back to CNC and it worked fine.
Also running from the same Mac? (not running Parallels or anything?)
A few of the cables below I didn’t check earlier as you said double check the connections. I did and I just had a good test run. I think I’m up and running again :man_facepalming:t3: Loose cable. Thanks for your time, it’s much appreciated.
