laser keeps stopping seconds into cut
Sounds a bit like communication problems. Try changing the USB cable, find out if your power supply is robust enough, see if there are electrical appliances with high starting current in the house that start/stop…
As a simple test, change all the power setting(s) to 1% and run the same job.
If it runs correctly, then the problem involves the laser power supply or its wiring.
If it continues to fail, then @bernd.dk likely has the answer.
In either case, copy-and-paste here any Console window text showing any error messages or a restart while running. Either of those will help diagnose the problem.
