I have a strange issue with my Creality Falcon2 Pro when trying to frame.
If I move the laser just before using the frame function, where the fan is still running … the frame works fine.
If, however, the machine has been idling for a while, trying to frame causes the laser to lurch very fast and immediately - and violently - is stopped. Here it will be stuck. I have to tell LB to stop. Hit home and then can frame. Let it sit again, and the same behavior.
As expected, I got zero help on Creality’s forum.
10:50:04.082 D: Command sending with timeout
10:50:04.084 D: “Waiting for response…” busy: true state: 5
10:50:04.085 D: O: “?\n”
10:50:04.086 D: I: “<Idle|MPos:0.025,0.025,0.000|Bf:127,65535|FS:0,0|WCO:0.000,0.000,0.000>\r\r\nok\r\r\n”
10:50:04.183 D: Command sending with timeout
10:50:04.187 D: “Waiting for response…” busy: true state: 5
10:50:04.189 D: O: “?\n”
10:50:04.190 D: I: “<Idle|MPos:0.025,0.025,0.000|Bf:127,65535|FS:0,0|Ov:100,100,100|A:S>\r\r\nok\r\r\n”
10:50:04.285 D: Got stream - sending synchronous
10:50:04.287 D: O: “G00 G17 G40 G21 G54\n”
10:50:04.288 D: I: “ok\r\r\n”
10:50:04.288 D: O: “G91\n”
10:50:04.288 D: O: “X91.975Y67.975\n”
10:50:04.289 D: I: “ok\r\r\n”
10:50:04.291 D: O: “M3\n”
10:50:09.039 D: Stop clicked
