Laser Machine Problems - Random Shifts
Assuming it’s a Ruida controller, delete all the files stored in its flash memory.
If it’s connected with a USB cable, that’s always good for random communication errors. One way to diagnose this is to Send the file to the controller’s flash memory, then run it from the controller without involving LightBurn. Lay down some cardboard, run the same job until it either misbehaves or you’re convinced it won’t.
USB cables are always the last thing:
Using the Ethernet connection eliminates communication problems, with the caveat that you must ensure the router on the LAN cannot assign the controller’s fixed USB address to another device using DHCP. This long discussion gives some background:
