Hi!
I’ve recently started playing around with Lightburn and my Orturo Laser Master 2.
I’ve used a .svg file of a grid with 20mm squares to use for alignment on my work surface.
However, the issue I’m having is that the positioning in Lightburn seems to be off. It doesn’t seem to translate to the printing surface. The size of the printing area is correct (400mm x 430mm) in Lightburn.
My grid matches up with the guides in Lightburn but when I go to engrave, the frames are off position wise.
Any ideas?
Thanks in advance!
