has anyone gone across this it works fine on fill and line but not in offset fill
thanks speed 1400 power 30
Offset fill especially at the high speeds that you are running are exceptionally mechanically challenging to the machine.
It’s likely exposing weak areas of the machine. Check belt tension and make sure that pinion gears are properly secured to the flats of the stepper motor.
If that doesn’t correct the issue then you may be just moving more quickly than your machine is capable of and your machine is losing steps. In that case slow down to see if that addresses the issue.
Offset-fill is not made for such detailed objects like letters. The beam width and size of the objects play a major role here. Text is to be done in normal fill mode, usually.
Anyway, the material is also not very suited for this kind of engraving,
