Laser Master 3 not found via USB
I posted earlier about the LM3 not working well on the network. So I decided to connect USB. The SD card shows up and so does /dev/ttyACM0, so I know the cable is good, etc. However, LB doesn’t detect and if I set it up manually it never shows connected.
Any troubleshooting ideas?
Is this on Linux?
Did you follow the Linux installation instructions, particularly on group permissions for “dialout”?
Installation & Setup - LightBurn Software Documentation
1 make sure you dont have lightburn open on another window, has it may be connected on there
2 make sure your on the correct port
Thanks for the replies. I actually had something else running that was trying to grab the port. My bad.
