hi dose anyone know if you can add memory to my 50w co2 laser.i would like to put photos on a 16inch by 12inche slate tile but it will only do half the picture on a tile that size as it runs out off memory,did short video on my phone but it wont up load
The practical answer is no.
Make sure that you’re not creating an unnecessarily large file. Specifically, what is the DPI setting? That has a direct impact on file size.
What would you call alarge file?and dpi is only 122
This will be limited by the storage on your particular controller.
Check if you have a lot of stored files on the controller. You may be running out of storage due to already stored files. Try removing them.
i delete the files after every project
