I will adjust my speeds accordingly and redo the scanning offset measurements. I will also redo the mirror alignment and clean them up.
With regards to the home switches, I can’t really get a good measurement as they are tucked away in the corner. Shall I reduce this or remove it entirely?
And, although I don’t have much experience with lasers, I did have the foresight to take photos of the old Leetro controller settings. I probably should have led with that now that I think about it.
I believe these should be the relevant ones, though I do have photos of the other ones if need be.
Edit: Now looking at those photos, I remember that I recently adjusted the speeds on the laser to be the same as those of the old controller. So I did have a higher speed setting when I did the scanning adjustments.
