Hi all, the laser module on an Atomstack A5 M50 Pro has stopped working because the black wire connecting the mini PCB board at the top to the cylinder inside the module has broken. Can this be soldered, or should I get a new module or update the module? Getting to the break in the wire will be difficult as it is in the narrow tube. If I need to get another module, can someone point me in the right direction, please?
I will give my soldering experience a chance, if it doesn’t work you can always buy a new laser head, so you can only win.
