My laser is moving but not engraving and I can’t get it to engrave, I tried to follow all of the steps and adjustments but still nothing. Please help
@Selah aside from simple solution of a plug loose… if you look in the Cuts/Layers to see all that all the settings are correct. I almost went crazy with no movement but Shift box worked. Then I noticed power was switched off in all the fills and lines …
Should the settings be different for different t materials? I’m not sure what settings should look like. Also does the laser have to be close to the item?
