Hola a todos , tengo una laser CREALITY FALCON 10W que de un momento a otro dejo de cortar y grabar, le doy orden de cortar o grabar y hace como qué corta pero no hace nada , el laser solo aparece en la superficie como una pequeña linterna de color azul, probe el modulo en otra laser y ahí si corto y grabo, ayuda por favor .
gracias
Hello everyone, I have a CREALITY FALCON 10W laser that suddenly stopped cutting and engraving, I give it the order to cut or engrave and it acts as if it were cutting but it does nothing, the laser only appears on the surface as a small blue flashlight, I tested the module on another laser and then it did cut and engrave, please help.
thanks
You confirmed the laser module is good. This indicates it is likely a broken wire or bad connection to the laser.
Could it be that the maximum power setting too low? ![]()
