Láser no enciende
Buenas tardes mis amigos.
Alguien me puede ayudar con mi problema con mi sculpfun s10 .
Ella se mueve normalmente todo funciona bien pero el láser no enciende.
Ya le mire los cables y están bien .
No sé si sea problemas de la placa o del modulo ya que todas las conexiones se ven bien
Dejo mi correo en caso tal que alguien me pueda ayudar kenier.05s@gmail.com
Things to check:
  1. Is the lens clean?
  2. Does the fan on top of the laser module run?
  3. Does the laser work with the Fire button in the Move window?
  4. Does the laser otherwise move normally?
Buenas noches amigo .
El ventilador funciona normal .
Los motores X y Y funcionan normal.
El láser no funciona ni en disparo .
Pero lo que me llama la atención es que la placa alumbra como si el láser estuviera trabajando normalmente
The fan is working normally.
The X and Y motors are working normally.
The laser isn’t working, not even in firing mode.
But what I find strange is that the circuit board is lighting up as if the laser were working normally.
This seems to indicate the control signal is getting to the circuit board. That board controls the voltage to the laser as the PWM signal varies. I know this technical info may be strange to you, but basically it seems the circuit board or the laser module is bad. Make sure it is not hot and causing a thermal shutdown.
There may be a button on the circuit board. Push that to see if the laser fires full power (Safety glasses!!!). If it does not fire, it is the laser. If it does fire, then the circuit board is bad.
I got a new 5w module that had a bad circuit board. I was told the circuit board for mine was not available separately. Good luck!
Muchas gracias mi amigo.
El botón que dices es el botón de reset?
Ese lo pulse y no funcionó
If it is on the circuit board on top of the laser module, I do not think it is a reset button. It is a test button.
