I have two lasers mira 9 and mira 7. I just set up the 7 with the piburn and had issues getting it up and running. It was telling me no laser connected. When I connected the cable directly to the ethernet inside the machine (not the connection outside) it worked. But today when I turned on the machine it’s telling me that it isn’t connected to a laser so I did the following trouble shooting
Checked that I’m connected to wifi - yes
upgraded the latest software of lightburn
unplugged/replugged the bridge
Took ethernet cable out and back in
Hit esc on the laser keypad
Hit reset on the laser keypad
Restarted the mira 7
Nothing has helped and I’m drained from trying to figure this out. The only difference I have done that I don’t see why it would bother the 7 is that I ran a job to mira 9 via it’s bridge yesterday. 7 wasn’t even on. I’m not sure what’s going on and I really hope this is a easy fix and a user error and not a deep dive into an issue. I have a pc – windows 10.
-lightburn screen shows disconnected
-When I go to devices – it shows my mira 9, mira 9 bridge, mira 7, *7bridge (the * was not there before)
scanning lightburn bridge devices - no laser connected but shows ip address of bridge. then shows 9bridge and address
-When I choose to edit the *7bridge from device list it shows - ip address that doesnt match the one of the scan
IP Address on laser keypad 10.0.3.3
bridge has two lights in back on and one in front on
directly plugged ethernet into the machine inside not outside port
could the ethernet cable connecting to machine and bridge be bad? it’s the one that came with the bridge
You’ll need to simplify these for me. I know just enough to get by but once it’s an tech issue i’m clueless. how do i check network log link and the port on the bridge or inside machine
In the screenshot that you sent there’s a link that reads “Network Log”. What happens when you push that?
Physically examine the Bridge. Where the ethernet cable plugs into the Bridge there should be 2 small LED lights located on either side of the port itself. Are those two LEDs flashing?
a long list appears on the network log… do you want me to screen shot the most recent items?
when i right click the devices. an hour glass appears and then disappears
Okay. That’s not showing what I would hope it would show. I was hoping to see a positive connection to the Ruida from the Bridge.
So right now you have what looks like LightBurn->Bridge connectivity but not Bridge->Ruida.
Does your Mira 9 also have 10.0.3.3 for the controller IP? If so, can you try plugging the ethernet cable from the Bridge connected to the 9 into the 7? Do not change anything else.
Then in LightBurn connect to the 9 Bridge which should now be controlling the 7 laser. Are you able to control the 7?
This will isolate if the problem is with the Bridge or the Ruida.
I unplugged the 9 bridge and used the ethernet cable that came with the 7 and plugged it into the 9 bridge. I then connected to 9 bridge in lightburn, sent a file and it went straight to the laser and showed up in the keypad correctly
i took sd card out of 9 bridge put it into the 7 bridge. connected 7 bridge back to 7 laser machine.
went to lightburn connected to bridge 9 and tried to send file
file transfer failed
is this what you wanted me to try?
Yes. To me this implies a hardware failure on the Bridge itself. If I had to guess it would be a failure on the ethernet port since it seems like wireless is working.
I’ll ask @Colin or others from LightBurn team (@JohnJohn, @JTR) to confirm diagnosis or provide other diagnostic steps.
