I have an Omtech Polar 510mm x 300mm work area and am trying to use Absolute Coords.
I draw a square with the corner starting at 200y axis, 200x axis on the LightBurn work area. When running the cut the laser makes the cut offset on the workpiece, It does not cut the square 200mm x 200mm it will be 20mm offset and not in the specified location.
How are you determining that the cut is offset? Are you basing this on the ruler markers on the bed? If so, from what I’ve seen those do not directly correlate to coordinate positions.
You can see this even after homing. Position after homing does not match 0,0 with respect to the ruler marks.
If not that, can you provide the following:
full screenshot of LightBurn with the design loaded and ready to burn
screenshot of Edit->Device Settings
Does this mean that the dimensions of the cut are not 200x200 mm? Or are you saying it’s just offset but the dimensions are correct?
Just recently I have measured 50mm down and 50mm across with reference to the HoneyComb bed that comes with the device and then drew the square on the material. I then done the same on LightBurn exact same measurements.
The square that is drawn is the size specified, no problems there. It is just the location the square gets cut is offset.
I’ll post the screenshots shortly of device settings and the LightBurn design.
Put a piece of cardboard that completely covers your honeycomb bed then draw a rectangle the size of your work area in Lightburn. Burn this at a low power and you will see how the honeycomb aligns with the actual cut area.My guess is that the cut area is smaller than your honeycomb.
Based on what you’re saying I’m almost certain it’s just the difference between position in the controller and the markings on the bed. They’re simply not designed to correlate.
If this is important to you then you have a couple of options:
Somehow remark the bed so that the rule marks are correct
Adjust homing offset. This would likely only work if 0,0 on bed is farther away than home position, but not the reverse. You should be able to adjust home offset for X and Y in LightBurn Edit->Machine Settings->Vendor Settings
Not certain but you may be able to adjust homing sensor location to match the bed but this may be impractical on that machine.
I will give #2 a go, moving the home position 5mm diagonal backwards towards the edge of the bed wont damage the device?
if not able to use the honeycomb bed as reference and line up a piece of material with absolute coords, how do you accurately centre a cut on the workpiece?
Apologies for being vague
I will draw a square on the material and then use the camera to trace the square in Lightburn. I then run the cut and it is also offset
