Laser not cutting since I moved the laser
My laser was working perfectly then I moved it to a new location and now it will not cut and barely marks the material. I’ve cleaned it twice and did the focus test with not help. It frames like its supposed to then when I hit start it jags super fast then acts like it cutting out my test square. Any suggestions? I”m using lightburn version 2.0.00. I tried the latest version did not work right so I changed back to this version. Any help would be greatly appreciated. Thanks
Maybe you switched speed units? mm/s instead of mm/min?
CO2 machine? You probably changed the laser alignment when you moved it. Check alignment.
