mwins83065
(Michael Winston)
February 3, 2025, 6:21pm
1
I recently purchased a used xTool D1 10 watt and I cannot get it to engrave correctly. The letters are on top of each other and reversed. Preview shows it correctly but engraver does not.
parsec
(FerAS)
February 3, 2025, 6:45pm
2
Did you create your device by importing xTool-D1-V2.lbdev and follow this?
DisclaimerIf you need to control xTool D1 through LightBurn, download the official release of the LightBurn software. LightBurn is third-party software, and therefore Makeblock Co., Ltd. shall bear no
parsec
(FerAS)
February 5, 2025, 12:39pm
4
Run the job in the following link:
Given one picture and four words, I think @JimNM has nailed it.
This test pattern helps identify mechanical problems:
GrundTest.lbrn2
Scale it to fit the platform and run it as fast as it will go in Line mode with optimizations turned off and power set to mark a sheet of cardboard. Any differences from the design will be informative.
Upload good photos of the result so we can look over your shoulder.
If the output is different from what shows in the Preview follow the below guide:
If you have more issues write back.
system
(system)
Closed
March 7, 2025, 12:39pm
5
