Laser not firing 1
Laser goes through the motions of the outline that I want but laser doesn’t come on?
Show some screenshots of your settings. How to report a laser problem - Diode Laser Wiki
Eric, make sure to check your power settings and whether the laser is enabled in the software. Sometimes it’s just a small setting that can cause the laser not to fire. Hope you get it sorted out soon!
I have checked all power outlets and all cables connected correctly. I ve changed the cables all back to mother board and results are still the same. Not firing from laser. $0=10
$1=25
$2=0
$3=1
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=1
$24=25.000
$25=1000.000
$26=250.000
$27=1.000
$28=1000.000
$30=1000.000
$31=0.000
$32=1
$38=0
$39=0
$40=100
$41=40
$42=1700
$43=5
$44=1
$45=1
$50=1
$100=80.000
$101=100.000
$102=250.000
$103=100.000
$104=100.000
$105=100.000
$110=6000.000
$111=6000.000
$112=1000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=500.000
$121=500.000
$122=500.000
$123=200.000
$124=200.000
$125=200.000
$130=400.000
$131=400.000
$132=200.000
$133=300.000
$134=300.000
$135=300.000
ok
$0=10
$1=25
$2=0
$3=1
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=1
$24=25.000
$25=1000.000
$26=250.000
$27=1.000
$28=1000.000
$30=1000.000
$31=0.000
$32=1
$38=0
$39=0
$40=100
$41=40
$42=1700
$43=5
$44=1
$45=1
$50=1
$100=80.000
$101=100.000
$102=250.000
$103=100.000
$104=100.000
$105=100.000
$110=6000.000
$111=6000.000
$112=1000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=500.000
$121=500.000
$122=500.000
$123=200.000
$124=200.000
$125=200.000
$130=400.000
$131=400.000
$132=200.000
$133=300.000
$134=300.000
$135=300.000
ok
Do you see any LED lights on the top of the laser module?
Check the wires and connector at the laser module.
Try a different program, like LaserGRBL - if you have the same issue then it’s very likely a hardware problem, and you should contact Ortur.
Like I said in the other thread, at least the steps/mm are incorrect. Reset the firmware by sending $RST=* and try again.
Problem fixed!!!
All it was is a minor cris cross two plugins near on the motherboard. Now I am back to the circle thing again. I am making more of an oval than circle.
Yes, because the steps/mm value is uneven. Do as I said before, then circles are round again.
