Laser not firing while framing
I have an Atomstack A5 M50. After a recent update to Lightburn 1.2.04 the laser stopped firing while framing. It does fire while framing when I use Laser GRBL.
Thanks
Steve
Make sure “Laser on when framing” is enabled in Edit->Device Settings.
If it is, make sure that Power % is set to a reasonable level in Move window.
Thank you for the quick response. It is set for enable fire button and fire while framing. Where is the ‘Move’ window? Are you referring to the Cut/Layers window? I don’t see a place to set the % for framing.
Thank you for your help. I was able to find the ‘Move’ window and the problem is now resolved.
Thanks again,
Steve
