This is actually two questions although possibly related:
1.) I noticed (at least recently) that the red laser cross hairs on my Atezr L2 36watt mchine are not showing where the laser is actually cutting. I had been under the impression that they show what will be cut, so when you run a “Frame” command button, it will frame the cutting area with those red crosshairs. how ever, it seems to NOT be framing the cutting area, it’s framing to the RIGHT of the cutting area, making lining up my position a nightmare.
2.) I also noticed (again, just recently) that the grid display in light burn SHOULD BE 410mmx410mm as I have my machine set-up to in the program (I did double check), but it actually is only displaying “410mm (x axis) and 240mm (y axis)” and I CANNOT understand why or how.
I am wondering if problem #2 is causing problem number 1? Although the issue seems to be the X axis not running to the correct place.
I am new to this, although did produce a few items already that didn’t give me grief.
The process I had been tryign to do, was engrave color into steel. I had been used a powdercoated steel sheet about 1mm thick, and it wasn’t burning through it, so I decided to do a clean burn of the coating off FIRST and then run my color sequence blocks over it (on the now bare metal). I successfully cleaned off the coating, but when I dragged my color sequence into the place the burn box had been on the grid, it REFUSED to print it there. (box outline had been deleted from the screen too)
So trying to line everything up, I’m relying on the red lazer cross hairs, but HOW to I get them to show where it will ACTUALLY be cutting?
Thankyou!
